YotaForge 3D products and feedback (1 Viewer)
Utah
I want to consolidate threads into this one for a more comprehensive list of items offered via one of my side businesses. This may be a bit preemptive due to few items listed at the moment but this will only grow. I currently design parts mainly for 08-15 lx570s since that is what I have easy access to, but I can expand into other years/vehicles if the demand is there.
First item I make is a 200 series cargo light. It replaces the access panel in the liftgate and is plug and play for the LX570 and power liftgate equipt LC200s. Trim panel is only available in black due to not finding a matching Nylon filament to other oem colors.
Second item is a 08-15 LX570 specific phone mount that's fitted to a blank spot on both driver and passenger sides. It utilizes a ram style ball mount to give flexibility with attachments. It's threaded with brass heated inserts so the ball or attachments can be swapped out In the future if needed. Can be purchased bare, with magnetic magsafe mounts, quadlock adapter, or Qi2 Wireless charger.
Third product is a bit more universal. I designed and angled mounts for roof rack auxiliary/camp lighting that utilize the harbor freight roadshock led pods. The pods are actually great quality for what they cost. If the pods are purchased as a kit, they will be prewired with Deutsche connectors. You'd obviously need to make your own connecting harness tailored to your wire routing locations. These do require two mounting holes to be drilled, they also have a template to aid in that.
For your Qi2 charger, are you routing the cables back through the dash, or do they still hang down to the cigarette lighter?
That depends on how comfortable the installer is with pulling trims. Mine is routed in the dash and have a hardwired usb a female tapped into the cig lighter. The 180 degree plug puts it in the perfect place to dive into the dash between the 3 different trims right there.
Fantastic. Thats definitely something I can tackle.
And since you seem to have the silver color of the dash matched pretty well, I would absolutely love to see a replacement lower panel where the cig lighter and seat heater controls are. Theres currently zero good way to replace the cracking wood trim down there and I think it would be way better to just do the whole panel. Maybe even with an optional aux switch panel instead of the ash tray. If I was better with odd shapes in fusion I'd have done it already, but will gladly pay to have it done too.
Ooh that's very interesting. I'll get mine removed and see what that would look like. I had planned to skin mine in CF with matte clearcoat since I've done that in the past, but that's a really good option as well.
Happy customer here. I have one of the cargo lights. Craftsmanship is top notch. Looking forward to future offerings from you!
Are you taking suggestions? I’m looking for a chase light mount for a stock truck. Sure if I get an aftermarket rack it’s cake but I don’t need a fancy rack, I just wanna mount some yellow Baja design s2’s so people can see me when I go to borrego or ocotillo!
Quad Lock is now an option as well! A little pricey due to their proprietary designed components, but still great for those who use them on other vehicles!
Would you prefer mounting inside on trims or outside on the spoiler? Spoiler would be a bit more work for the end user due to running wiring through spoiler and likely riv nuts to mount chase bar. Inside keep things a bit cleaner, but obviously will impact visibility a tiny bit.
Now also offering a grab handle ram mount for whatever accessory your heart desired. Revolves around a 25mm ball mount.
