Build Yeller Gold
For awhile, I had a “cheater” lens in my welding helmet. Worked pretty well. New helmet I have I haven’t seen any magnifier lenses yet.
So far my only pair live in the shop, I’m sure that too will come to pass.
I keep a set of these glued to the back of my cellphone at all times.
And I buy the "Kerecsen 6-Pack Reading Glasses Blue Light Blocking,Spring Hinge Readers for Men Women,Computer Eyeglasses (6 Black, 1.5, multiplier_x)" glasses a dozen at a time on the Amazon and scatter them everywhere...
Ya, understood. I take em off up close and put em on to drive 😵‍💫. The New style headlights **** Me up and cause blurrs always even daytime 😎. That's why I wear my Sunglasses at night 😎. Ooohhhh dat Huwie Luwis song 😵‍💫😘🧐🤔😲😳😉🤪🤣🤣🤣🤣🤣🐖👈. Im a Rockstar 🐖👈🤣🤣🤣🤣🤣🤣
That's not Huey, he wants a new drug!
I’m a big fan of thin optics. I buy their regular reading glasses and they are the only ones I manage to not break within 5 days.
Just thinking about the missing link for the steering, need to connect the PS box to the rest of the world…all 60 series ends but when I look up 60 series drag link it’s 33 inches.
Discuss…best option is?
I have a Budbuilt draglink and tie rod on my '85 4Runner with FJ80 tie rod ends. Much stronger than the factory set up. He makes them to order and you can specify the length(s).
Ordered my Borgeson 24” shaft and joints today 💸 about $300can, which isn’t bad with our exchange rate right now.
Two of three in stock, other be a couple weeks on the stock order, no real rush.
I have lots of OEM p/n's in my PS thread.
I found the 70 series piece to make it all work.
OR, you could cut the drag link to fit. One end has LH threads - leave those. Cut the end w/ RH threads and re-tap!
I made mine out of 55 and 60 series pieces.
I started digging in your thread but realized you have stock width axle, so the drag link length is different.
The DOM route is likely, I’m going to call a couple of local shops first before I go try to go it alone on that.
Beautiful sunny day up here, I got the M56 warmed up and aired out, moved it in front of the garage (that it should be in🤬) and got the battery maintainer on it.
Then rest of the afternoon in the shop, trying to square up the Saginaw pump with not much to measure off is a slow go, but I made some progress.
