www.xenondepot.com
Get the H1 Xenon Depot Kit. Jim Chow and i have them in our LX470s. Jim did a light meter test and it came to be 4x as bright as the orginal halogens.
Heres a thread on it...
http://www.clublexus.com/forums/showthread.php?t=210723
Thanks for the heads up, guys! I've been looking into this swap for some time now, and this is the first I've heard of such a simple retrofit.....Any reason the two of you went with the 4.3K vs. the 6K or 8K? I'm not sure I know the in's and out's, so any advice you could offer would be helpful. Thanks!
Just got my kit in yesterday......If I can figure out where to mount everything, I'll be installing in the next few days
Info on part #81125-6A080...
My local dealership want's $42 each for these covers. I called Sewell Lexus to see if it would be much cheaper and they also quoted $42 each plus the required shipping.
To say that these covers are just a few bucks is a little misleading. At about $85, this is a significant expense. Be careful drilling out your caps. I used a quarter (.25 cents) for a template and it worked out well for me...but I won't be buying these replacement caps to have laying around for $80. Lesson: drill the caps out right the first time.
Also, I installed a Prolumen H1 5K kit and I had to move the bulb around in the bulb holder to get rid of the hot spots. I made some shims to shim the bulb out of aluminum foil tape and now the spread of light is perfect and the cut-off is sharp...not the case if you just put the bulbs in without moving them around a bit to find the sweet spot.
Got the kit from a groupbuy on Bimmerforums for $255 shipped.
