woofer in lx450 (1 Viewer)
lx450landcruiser
Moderator
Seattle
if i took out the woofer in my lx450, the one in the center thing and replaced it with new one, a better one. would the stock face plate be able to handle the power? would there be any diff or no?
thanks mike
wulfer in lx450
Thats a woofer Mike, woofer.
Cheers
Sean
Look for a speaker with a higher "sensitivity" rating. This will allow more volume with the given amount of wattage provided by your stock unit. Nearly any decent aftermarket speaker will have a higher sensitivity rating than those that came stock. Unless you're wanting to drive a massive woofer with your stock unit I wouldn't worry about the power side of things.
I swapped out my stock woofer for a 6" JL(need a new amp though). It was in the way back. To seal it better I put rubber cement and silicon around the inner edge to give it a better sound. That might work for you if you don't want a vibrating panel.
