They are building out the foundations and slabs that were poured back before the SHTF.you still have construction sites around you?
From the link Trollhole posted, cribbing is an acceptable way of supporting things.
But if you're thinking of nailing or bolting something together with the wood running vertical, I really wouldn't... You could properly engineer something with all the loads figured out and the stresses and all - but unless you're willing to do all that better to get some sturdy steel jackstands.
use proper bridge blocking technique. we support 260 tonne uclids at work with 12x12 blocks . if you have to block a shovel you would probably switch to iron wood instead of the basic soft wood . oak is great but its awfully heavy . same as iron wood .
i could supply pictures if needed
