ARCHIVE Wits’ End Gentex Mirror ARM (2 Viewers)
And finally wired it up. Home link is my favorite part about it. No more looking for a misplaced remote.
Anyway the arm is solid. Love the extra mounting points!
Which model (or what vehicle did it come from) is that? I found a Gentex 453 out of an 06 Maxima for $12.00 at LKQ Pick Your Part. The integrated backup screen would be nice.
Ok so all BUT 5 of you have received your mirror arms. To the last five that ordered I'm really sorry. There was either a machining error (the arm didn't fit into the block pocket) or the powder coating looked like ass. Machining or stripping means tolerances are blah. I'm re-machining another batch of these so that I can send these out. Sorry about that.
I got mine! Quality work as always.
I just used a 177 model that only has auto dimming and the compass thingy. I wanna say I paid about $40 for it from the bay of e
What model has all the bells and whistles (cam/temp/home/compass/mirror/etc.) with the easiest wiring? I've found a few OEM models and a few branded models but can't make sense of what the simplest and most inclusive solution is. Any tips?
Its a GHSHL4, I believe from a Subaru. I wish I could say it was $12.
Edit- should have refreshed the page first. Thats the one I used, has everything but temp. Its the 12 pin version. Wiring info is here, somewhere down in the comments:
https://plus.google.com/104597817731367617560/posts/ZyDE69oyEF2
And another edit- connector and female pins for the 12 pin gentex mirror:
1318774-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
1123343-1 TE Connectivity AMP Connectors | Connectors, Interconnects | DigiKey
Thanks!
Next batch is getting close. Arms went to powder coating and blocks going to anodize next week.
Powder coating will be done on Monday as will the anodizer. two of the pieces need to get laser etched then orders can ship. Right now looking at end of next week.
I think I found a mirror with all of the features I'd like but it also comes with onstar. Not exactly sure what onstar does besides help you in an emergency. I'm curious, does anybody with onstar experience know if that feature will still be functional?
Not without subscribing to the service.
Gentex actually sells an aftermarket OnStar equipped model with all the sensors and what not. They are sold at Best Buy. I don't think a standard GM unit would work as the sensors are in the actual vehicle.
Are these in stock? I'm definitely interested!
Only problem is I stripped the head on one of the screws that holds the stock mirror when I installed the ARB Outback roof console a couple of years ago. The screw just wouldn't budge, even with an extractor. I had to drill out the head and now only 1 screw is holding the front part of the console and the mirror itself. Do you think it could still support the weight of this Gentex mirror arm?
PLENTY available.
The mirror weights nothing but having only one screw holding everything??? :hhmm:
PLENTY available.
The mirror weights nothing but having only one screw holding everything??? :hmm:
Just placed an order! :) Kindly ship it in the smallest box possible since I'll be using a parcel forwarder to ship it to me here in Manila. I left a note at the order comments but I'm not sure if it went through. Thanks Joey!
Yup no worries.
Got the mirror arm today. Fit and finish is top notch! Very sturdy, no wiggling at all. Only issue I encountered was that because the new base is a bit longer, the stock mirror snap-on cover wouldn't fit flush because it hits the ARB Outback roof console.
-EDIT
I just used a little more force to snap it in and now the mirror base cap fits perfectly. It's great to have a lot of mirror choices!
