Hey, all. I thought this would be a much simpler thing to research, but there is a lot of conflicting info out there. I am wanting to install an antique dash clock in my FJ45. Most antique dash clocks run off 6V systems with the FJ, obviously, being 12V. What is the easiest, and safest way to go about doing this? I'm no electrical expert, but I did install a complex stereo system in my FJ and redid a lot of the wiring, so I'm confident I can get it done...just not sure the best way. Whatever way I choose, I'd either wire it directly to the battery with an in-line fuse or to an "always on" peripheral.
1. Simple voltage drop device, inline, between clock and 12V battery - I reckon I'd have to worry about current being too large. I could replace the wiring on the clock with something thicker, but not sure what the higher amperage would do to the clock. Don't want a poor running clock or a fire hazard.
2. Could I run it off one of the outputs to the voltage regulator? Not sure if any of those outputs are 6V. TBH, I'm not sure if the voltage regulator actually has any "drops" in it's circuit or if it only serves to cut on / off alternator current to prevent overcharging of the battery.
3. Should I just throw in a separate 6V battery and wiring circuit? I searched on some antique car threads and quite a few people just threw in a 6 volt battery (into their 12V converted vehicles) and wired the dash clock directly to that - saying to just remove and charge the 6V battery periodically. I don't wish to do this...sounds like a non-ideal solution to something that shouldn't be so hard.
3a. What about a separate 6V battery that is connected to the alternator through the voltage regulator (to prevent overcharging) but with a voltage drop in-line?
Anyone done something like this and can advise on the most appropriate method?
TIA!
TIA!
