Apparently some "enthusiasts" are spending big $ on gimmick wiper blades. I know it's easy to snap in a complete blade, or have the counter guy at AutoZone do it for you. Maybe some people don't know how simple it is to replace just the rubber refill. Toyota blades have been top rated by testers, these refills cost about $10 from cDan/Beno, probably a couple bucks more at your local stealership.
So here's the Wiper Refill for Dummies.
1. Take the blade off the wiper arm.
- squeeze the plastic tab at the center toward the metal wiper arm, and slide the blade toward the windshield.
2. Slide the old rubber off the blade, just give it a good pull to unhook the end.
3. Transfer the stainless stiffeners to the new rubber refill.
4. Slide the rubber onto the blade.
5. Snap the blade onto the arm.
If you don't do your own maintenance, this would be about the easiest mechanical thing you can do to get started, edging from "owner" to "enthusiast".
