Thought I'd post up what I found when I pulled the original windshield wiper motor. It sometimes would run slower and was making a sorta growling noise which was more noticeable after I had removed the wiper arms. With the motor apart I found that the magnet on the bottom side of the case had come loose, probably due to rusting of that side of the case. The case was not designed with an O-ring, it might originally had a swipe of some factory sealant but it looks like that dried up long ago. The brushes after all these years still have some useful length remaining.
The photos show how the steel of the armature had been grinding on the magnet which was (magnetically) stuck right up to and riding on the armature, surprising that the wipers worked as well as they did. The bearing for the armature shaft was a bit rough feeling when I spun it by hand, dry for sure, and it's an uncommon size; 9.8mm ID x 20mm OD x 6mm high/wide. The number stamped into the shield of that NSK bearing is B9Z-32AZ. The armature has a captured ball bearing on one end of the shaft that's lubed by oil soaked into a packing at the pointy end of the motor case. After 16 years that ball bearing and the packing were still wet with oil, would be interesting to know what type/brand oil was used originally. Plan is to install a lower mileage wiper motor I picked up awhile back and rebuild this one eventually.
