Looking for some advice in removing the windows on a 1984 landcruiser wagon
While we're on the subject of windows...
My Driver's side window-when lowered all the way-will move around inside the door.
When I replaced the whole regulator assembly, I noticed that down at the bottom(front of glass)where it goes into the channel, it seemed to be missing something causing it to be loose.
Any ideas?![]()
I replaced the window run on both front windows on my 60, and both were missing some of the rubber. Replaced with OEM (two parts) and no rattle, goes up/down easily.
In your case, you are missing a piece of the window run.
I used the rocks to remove mine![]()
