In case you have trouble using the link...
1988 Toyota Land Cruiser Base 4.0L, 6CYL Automatic
187,000+ miles
Beige w/brown interior
31x10.50 r15 Milestar Patagonia Tires
The engine starts and runs great. Idles at 650-700 rpms.
Transmission shifts smoothly, Transfer Case and 4x4/Hubs work
Since OCT 2021, De-Smogged, (I have the complete EGR system)
New exhaust form the manifold back (including 2 O2 sensors, Cat and Muffler)
4 new U-Joints
Tune-up (Plugs, Cap Rotor, Fuel Filter, Hoses, Air Filter, Throttle position sensor,
Thermostat, Disconnected rear heater, valve cover gasket, Charcoal cannister,
Cold Start injector cleaned, Fuel Pressure Pulsation Damper replaced)
All new fluids throughout (engine, trans, transfer case, diffs)
Alignment (which it needed)
New bushing for the shackles (front and rear)
New OME steering stabilizer
All lights, exterior and interior, work (high beams work intermittently)
Seats are redone in tan/brown vinyl w/matching door panels
Replaced the vapor barriers and lubed manual window regulators
I am sure there is more I can’t think of…
Things you need to know:
Has a rebuilt title. It was reported stolen in Pennsylvania
Insurance was paid, vehicle was later recovered and sold at auction.
The title is in my name and insurance through USAA (no issue with getting either)
Rust: on the cowl, at the bottom of the windshield the paint is bubbling and the paint is bubbling behind the passenger rear wheel. (I will take pictures)
The frame is solid. Looks like it has been treated with fluid film previously.
Oil leak: I believe it’s the front part of the oil pan gasket. At speeds above 60 it blows back under the LC and up onto the rear of the truck. Seems like more than it is. I check it all the time and it’s been 2000 miles since the last oil change and I haven’t had to add any oil. Overnight, it leave a quarter sized spot on the floor.
Cowl and hood are bent in a couple places. I do not what happened. I have a rust free
replacement cowl that goes with the truck.
The interior is pretty clean. The plastic shell on the steering column is cracked, the shifter cover is cracked, and the dash has a crack or two.
Seats are in good condition and work as they should (front and Rear) The center seatbelt
teceiver is broken. Missing one of the head rest for the back seat.
I will be taking pictures later today. Please feel free to ask questions.
The price is $17,000 firm. I’m not trying to make any money, I feel it’s fair and I have more than that in it.
