Winch Mounting ARB
Just acquired Superwinch x9 and trying to mount Superwinch X9 in ARB. The motor and and gearing on each side are catching and cannot mount into brakets on winch mount. IS the Superwinch X9 not going to work in the ARB or is some sorta shimming required? Any suggestions?
I believe the 80 series ARB bumper is designed for the Warn 9000M winch. The 12000 will fit with a bit of grinding.
What you can do is go to each web site for the warn and superwinch and check the pattern or blueprints. This will give you an idea. Or call ARB direct and ask the question. I can not remember if any one has done this before. Have you tried the search funciton? later robbie
