Ive made a new front bar , but realy only have the 2 12mm bolts at the end of each chassis rail too attatch it too.... The smaller bolts on the side of each rail are either stripped or i cant get a bolt in with the winch mounted... would the 2 12mm bolts be enough if i use grade 8 or 10 bolts ?
i have stuffed an 80 series winch right in tight , but it has too be fitted too the bar befor i stick the bar on .
