I broke two installing the flywheel on my 71 1f. Can I get away with this or should I spend the rest of the day trying to get them out of the crank?
Thanks
Andy
Thanks
Andy
Will 4 flywheel bolts do?
Can I get away with this?
shoulld I spend the rest of the day trying to get them out of the crank?
left hand drill bit and an easyout
Have an engineer calculate the amount of energy that flywheel will be carrying at 2000 rpm. Then imagine that amount of force coming through your floorboard at your ankles. Then get some new bolts and properly torque them into place. Just my 2 cents.......
it has to go thru the input on the tranny also with the clutch disc under-pressure between the clutch and the flywheel..
Coincidence? I think NOT!
