I've had a couple of tandem axle trailers and they have all performed very well for their designed function.
They are very smooth running down the road. I guess that is because they split the shock of bumps across the two axles over time (yeah a very short period of time at 75+mph).
However when making tight turns, especially when backing, the two axles seem to resist and have to drag the tires around.
What would the disadvantage be to having an open trailer w/ one 7,000lbs axle w/ 8 lug wheels (8x6.5) the same that are on most 3/4 and 1 ton pickups (spare tires could be interchangeable... another advantage!!!)
just a thought...
using a single 7,000 torsion axle you could just weld a toung on and some rails for the tires to sit on, string up the lights and brakes and be on your way...
just a thought...
