www.gotpropane.comGreenWeeny78 said:Go propane, a lot less head ache and its better than fuel injection when it comes to off roading!
too tall said:You could use your original intake and just put an adapter on it for the TBI . It might make it sit a little higher but only about 3/4" .The rest of the ports that you need you should be able to find or adapt.I haven't done it this way but I've built a couple of tbi setups from scratch for 2F's. The only other thing is the knock sensor and you can use the fuel pump block off plate for it if you want.You just have to tap it out to the correct npt size. You will also need to change the dizzy or you could modify the original one to a 7 pin module for the dist. hookup to the ecm ., When you find the donor make sure you get everything you need or think you might need .The esc box and the knock sensor are more important than you might think they control all of the timing advance.The wiring harness isnt that bad either if you wanted to build your own one . remove the looming, hook up all the sensors ;dist.,fuel pump and relay and the rest is pretty easy .Pink/Black -switched pwr ,Orange -to the + side of the Batt. and some grounds - Blk/wht , tan/blk or blk there are some variations but that should make it run . Also make sure you use metal filters for fuel they should be for Fuel injection.I always put at least one in front and one behind the pump when they are inline.hope this wasn't too much info and helps you out a bit.
bandy rooster said:what intake manifold do i use? can people just tap into the regular carb manifold and install the sensors in there appr. places? (edelbrock manifold) From what i've heard either the manifolds from carb to TBI's bolt holes don't line up or the angle is different on the heads... so what do i do?..
I'm doing the same installation but is it necessary to weld in a o2 sensor? Regardless of pre-smog?
I'm running a 92 setup on a 96 vortec rollerblock with vortec heads. I run a stock gm harness, it is great, just get the hole thing .Clean it up get a big table and a contnuity tester and label, label, label. Go to TBI chips.com and read some of his pages. He burned my chip for me and did a bang up job right out of the box. He has since burned me some new chips after datalogging. I love my setup, will run on its lid.
