Where is my EGR Temp Sensor?
Central Arkansas
Perused many threads on disabling the EGR, pretty straightforward, but seems my EGR Temp Sensor is not where it's supposed to be?
According to cahill's thread, PO401 and EGR/air intake manifold with pictures it is #3 in this photo:
And here is mine:
Should be where my finger is pointing, or am I losin' it?
And just to double check, aren't these the vac lines to loop/cap in order to disable?
Thanks for the help guys!
the temp sensor is in the egr, it looks like a small o2 sensor and has a 2 wire connector on it, should be #3.
also looks like you have a bit of a coolant leak, might need new clamps
ya sensor is on the back side of the valve. lucky you that you have an obd1 truck so you can just disable the egr system and not worry about it
Here's a decent shot of the EGR Temp Sensor (89412-50010) on a December 1994 California FZJ80, with the plug, wire, and actual sensor marked with red. I've never seen a diagram that shows it like this.
