- Thread starter
- #21
Medic, make sure you get the spacers before the tires are installed. The strike face of the steering knuckle will do permanent damage to the front two tires if you install them before the spacers go on. I went through that process a few months ago, not cool.
Tires are sitting here waiting to go on. 1" wheel spacers from JT will be here on tuesday. So, tomorrow I will be cranking the front up. Tuesday, I will be installing the whole new setup. The wifey's gonna love it!
I remember reading a post somewhere talking about (i think) the minimum width a spacer should be (should one use them) and not having the need to file down the studs. Can someone here correct me?
Also, with a stock rim ( in my case stock 18's), I'm thinking about possibly getting the duratracs in the 275/70/18 size. Does anyone know what size spacer may be required to make the rim/tire sit "flush" to the edge of the fender?
Also, does anyone make hub-centric spacers for our 100's?
I went with 1". I had the guys at JT look into it because I wanted to run the smallest bolt on wheel spacer I could. I was gonna get the Hub centric ones for like 420 ish shipped. I was told that they arent needed so I went with what everyone else is running.
Per Eibach's website, they have hubcentric spacers for the 100 series, in 25mm and 30mm thicknesses. Word of caution... the pic shows a 5-lug spacer, but the spec states 6-lugs. Perhaps someone at Eibach could clarify.
Havent seen anyone running these so I went thru JT
