No. Just push the shaft in a bit and access the bushing from the back of the hub.You need the special Slee tool for the spindle bushing correct?
When the shaft is pushed in from the outside, you get only to the backside of the flat (thin) brass bushing and to the exposed part of the shaft. The needle bearing is just behind the bushing and you should clearly see the needle marks in the grease on the shaft. The brass bushing is not very tight around the shaft - there is space. If you place grease around the shaft, outside the bushing, and press the shaft into the hub again (towards the outside), the grease is pressed into the spindle. When the seal contacts around the shaft, there is still a good cavity for 2 handfuls of grease -- and when you press the shaft further in, the cavity is reduced to near zero. If the grease does not come out around the seal, it has to go into the spindle. It's like a built-in grease pump. Try it and see for yourself.From what I could see in the Slee grease tool write-up, there is no way you could properly grease that needle bearing with either removing it or using the Slee tool. You'd just be smearing it on the outside service. I'll need to purchase the tool as I don't like doing the job half ass.
