Do a search. There are well documented and illustrated threads on this issue in here.
Behind that blank is a PCB, and a small switch wired directly into an ECU. You could use it by cutting some copper traces and design your own circuit with a relay.
FWIW: My '99 similar blank switch is just a cover plate that covers an actual 3-position switch (hi, low, off) for the rear heater fan. Just pop the cover off Stan and I bet you see more than a blank hole
I'd have to look at the '04 EWD to determine what the switch's purpose is for your blank location...
And the link to my build, where I used the 2-speed heater fan circuit, won't be correct for the rear A/C switch you will use...sorry I didn't catch the fact you have a '98...and mine is a '99 ('99 got rear A/C but gave up the 2-speed rear heater...).
