What tools and other things I need to complete spark plug replacement? (3 Viewers)
Wisconsin
I'm thinking about replacing my 2014 LX 570 spark plugs. I have never done spark plug replacement before so this will be my first. So what tools do I need or want to have to make my life easier doing this job. I have seen other YouTube videos showing greasing the coil before putting it back in; however, others do not show this part. What are somethings I should look for and/do? This is the part number of the spark plug (90919-01191). If this is wrong, let me know. It looks like my local shop do carry this spark plug; however, I'm not sure if it's OEM or not. The image on the local shop shows "Denso SK20HR11" I think. The description said: Gap 0.044". Iridium Long Life. Denso is OEM, iridium long life plug.
Denso plugs are fine.
As for how to do it someone here did a write up, and there maybe a youtube video?
It's an easy job .. but there was one plug #8? that you need to loosen the lines/tubes so you can get at the #8 plug.
Tools.. socket set.
They put high temp grease on the coil so next time it doesn't break coming off. I did it on mine.
I followed these two write ups from the forum and it went smooth.
Thank you for all the help. I'll give that thread some reading and see if I have any additional questions.
Tools.. socket set.
Are you referring to the dielectric grease? I'm assuming it's. the Permatex 22058 Dielectric Tune-Up Grease. How much do you put on it? Thanks!
