sweetShould we start the sodomy now? He has 8 posts, has not conducted a search, and obviously not read many of the threads or he would know that asking this must also go along with what oil should I use, what front bumper do I want, and how much lift should I put on my truck?
We all know those are the standard newb questions, but should we be nice or should we sodomize the living hell out of him?
Here are you standard answers:
BFG KO2's 285/75/16
Goodyear Duratrac same size
Toyo MT 315-/75-16
Cooper ST's same
Oil:
Rotella-t in 10W-30
Dino oil in 5W-30
Synthetic (Mobil 1) in 5W-30 to 15W-30
2" to 2-1/2"
ARB, AOE, and about 50 others
Lift brands:
OME, Slee, Dobinsons, and many more.
Things you NEED:
50 QT refrigerator
RTT (Look it up)
Ditch Lights
Bitch Lights
Bigger alternator upgrade
New coolant
New radiator
Fix your PHH
Change your intake tube
Buy a snorkel
Dual Battery setup
LOTS of LED lights
MANY cameras
Double Cardan Driveshaft
Sliders
MUCH larger tires
Lockers front and rear
Corbeau (or equal) seats
Replace your fuel tank
headgasket
fuel filter
Wiring harness by the EGR valve
Window switch from SwitchDoctor.com
Search for your local clubs
Learn how to use search
Grow thick skin
A credit card with no limit for fuel
Beer.
LOL, Thanks for the witty reply. For oil you guys should check out the walmart synthetic. I use it in the 67 Shelby and the Boss car my 69 bronco the mower and power washer. 18 a gallon versers 26 for mobil 1. Picked this land cruiser up it had been sitting since 2009 torn apart, finally running. Ok explain the head gasket joke, it had the head changed and they never finished it.
just wondering opinions on tire size and brand for a stock 1996 with the stock aluminum wheels do you guys like on you rig. Won’t be off road that much.
Thanks
Don't listen to any of these clowns, especially nukegoat. They're just going to make fun of you because you're new. I'm not here to do that, friend. I was once new too, so I know how daunting it can be. I'm here to help, so you can trust me.
You can go as big as 787.4mm tall tires, but because it's a Japanese truck, they need to be Japanese metric tires, not that dumb imperial s*** that American trucks use or that queer European metrique garbage. If you use any American or European brand tires, it'll void the warranty and the computer has a sensor that can tell what tires are there, and if it senses they're not Japanese metric tires, it'll cause the head gasket to blow as a precaution to keep you from driving on non- factory spec tires.
