I'm looking for jerry cans for gas for carrying on bumper. What are some brands/types that you like?
I've not found where to get them in the USA yet.Scepter military fuel cans are about as good as it gets.
Are the Scepter Jerry cans sold by REI here in the states not recommended then? I’m not sure if they are military spec.Scepter is the only "jerry can" I will use. Can't get them new in the US any more. I think Canucks can still buy the original style (same as the Mil-spec ones). Get a Canadian friend to buy them for you and send them south.
Mark...
This link is to the Scepter water can. These are in fact the same one the military uses. This is not a fuel can.Are the Scepter Jerry cans sold by REI here in the states not recommended then? I’m not sure if they are military spec.
And if they aren’t as good as the military ones, can you say in what ways the military ones are better?
I’m just starting my search for Jerry cans so any info is helpful.
I like the Wavians, I've had 2 for 15 years and they don't leak. That new spout is weird.Scepters are good. Also I've had a couple Wavians for almost ten years now and they've been great.
I just don't like the new style of spout. I use a more traditional spout with no spring loaded open/close
Scepter all the way, recently picked up a few scepter gas cans and a water can. Really surprised how fast 20L of fuel will pour out of one.For the Sceptre MFCs I did refurbish them. I got the aluminum flange and new viton seal. Aluminum Cap Flange with Viton Gasket - https://jagmte.com/collections/scepter-mfc-accessories/products/aluminum-cap-flange-with-viton-gasket
I also have straps to make it easier for my wife and me to pour fuel. Easy Pour Dual-Handle FUEL Strap for Scepter MFC FUEL Cans - https://jagmte.com/collections/scepter-mfc-accessories/products/easy-pour-2-handle-strap-for-scepter-mfc-fuel-cans
The fuel wrench is needed especially when going up in altitude.
Scepter MFC FUEL Wrench
***IMPORTANT***This is for the Military FUEL cans and will NOT work on the military WATER cans. WATER WRENCH is available HERE. THE ORIGINALM.F.C. CAP WRENCH for use on the Scepter Military FUEL Cans Never again struggle to remove an over-tightened cap, a stuck cap on a swollen can or to remove...jagmte.com
This is the vendor I have used and been very happy with his wares.
I run 2 gas ones with red straps and 1 diesel one with yellow strap on my Trail Tailor rear bumper carrier.
I mainly use the good old ww2 german design. They have design feature after design feature that you won't find on any other model, and they're standardised enough that you can find one at pretty much any hardware store (in Finland anyways). The triple handles allows you to comfortably carry one in each hand, two in each hand, or help a mate carry one. The cap is very durable, locks open when pouring, the gasket can be replaced, and you can attach any custom or store bough spout to it in a matter of seconds. On top of all that it's the best looking variant out there. Rust inside hasn't been a problem for me, with both diesel, petrol and empty cans. To further prove their reliability, all the ones I have say "made in ussr" on the side, and none of them have any problems whatsoever despite being at least 35 years old and made in a country famous for bad steel.I'm looking for jerry cans for gas for carrying on bumper. What are some brands/types that you like?
I dislike the factory spout on my diesel rotopax that it leaks. Have you had a similar issue?Have you thought about using Rotopax?
RotopaX | The Worlds Toughest Mountable Container System
Home of the worlds toughest overland, offroad, accessory fuel containers, water containers, and mounting hardware. Rotationally molded for unrivaled strength with multiple mounting options available. Find the perfect fuel container for any adventure.www.rotopax.com
