what is leaking...?
Most likely valve cover. Clean it up, slightly tighten the valve cover bolts, and see what happens after.
e9999
You want to do what...?
Moderator
US
could some be coming from the rubber hose on top of the valve cover?
Is there any oil on the front of the engine like this? On the right side of the engine, the air is moving upward from the fan rotation, so I'm wondering if it's something forward more that is getting blown backward and upward. Also, check your PCV valve/hose. Poor shot, but looks a little like the hose has quite an accumulation where it joins the valve cover/PCV valve - missing a wire clamp, too?? That hose will get oil accumulation in it from normal functioning and then a poor/unclamped joint will let oil out there each time you shut down. From there it could get blown all over. Chief suspect.
DougM
Memphis, TN
no oil on the front on the engine at least any that looks remotely new..
the right side of the engine when looking towards the wind shield?
I know my valve cover gasket is leaking but there are a couple of places, 2 of them i tried to show in the picture that looks like its leaking reddish stuff in that has not been caused my the valve cover
thanks for the input, i may try to get more pictures up tomorrow of the spots I was talking about
what i probably need to do is just fix the valve cover gasket and go from there.
powderpig
Boulder Foothills, CO
Head gasket is lower, you have oil leaks more than likely. That is what it looks llike to me. Start with replaceing the gasket and spark plug seals clean the engine (might want to check valve clearence). That is if the bolts are tight. later robbie
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
