What holds the radiator in place? (1 Viewer)
Portland, OR
I'm working on my BJ42. I started to notice there is nothing holding the radiator into place inside the cradle because the two hoses? It's just put into the metal cradle with no bottom bushings, top tie downs or anything from the side. What is supposed to hold it in place and what is supposed to be on the bottom to prevent the metal on metal from rubbing? part numbers?
Do you have full access to toyodiy.com? They have all the diagrams and part numbers there.
I think you are missing some parts. There should be some felt bushing at the bottom(I replaced mine with rubber) and some metal stays with rubber bushings on the side of your cradle to the chassis and battery housing ..
81CGO9Qy4FZZZdMCjHa61zHxjDwNXLOH9UNSAijWdFLgA7c9JHLZV6LlrDenWDqE2kKz3iVaxQ4OhilL-k07vTGUEoTC8kuj8sB1OWQziKEYW9zwDO3FEvgztW5y0KeTALsXH7dPN3xZwriPTek7rb5wSxCWetoLlSuZZ54IABunKKN3lGhSl1ViXvLt8ANuhBl4gHPcFdeQW04ACnJVdfvvsyR7M6jWfInmsbZRdos5uOB1qXSm_jI_FnHy-Q3QSmQjKnULXBycHezszng44WqWippntuEkhAKQHh0eCXTHnlecoJxzAArvoZ6jh4GUzHS2aZ-8DQZNT3ZEIQ5Av6kijBGCESHJLUuJsxW2VBC7cCQ1uO3tCUwjay60bQrlMM7v_V47MgKsCaqSKTwnFahRoVVg0UuJZE_5lFdSbIXeBAqsp3Bf0btcAkCDIDFTgrLR-AsuJgcW1iOBZZ9LjD-qWTOmICaBgFLxWFWaaj2-o25CLYRL-lK9BsBtzIIjoIicpWb74WHM2zCYOl6Q5_6K5T4BglMsySXfOlmcuE-0l7ZsH1EnR2nkysRu1uFIhueb6CcB_asZEi1DfMmsmPPcd7xQfkSJrpNCy5QiYhtzZvLjSHSfOL_xCCp9rvlTA1jD2v0WtGyNWUQRBRU_PJVTW-seZeIf2KgxIKMCe5FWQSblTovRFQ1PrPcvKA=w1188-h789-no
tHGkHQP0hIB-5qvAu-4sh2klPsf1zvWF6Xnu8GvlfX0BjN9KksfZW5wwPNbKEmYz08cim43mh_mp_GqdatAT-bNJs-_zQ_Dn0nt1XrcFvWXs6HehMLQ_QbeiiX7WVnfHXK9yJBwKuLEQTjlDRSjfaiUqT5UpXu-G2tKqvSyMIMe2KIGHaSJhbi42mknojPDKAIDsKY0HmFD2kVpwJ8XiLGhBws_lZMkswOp5AaCNiuQ09OY9-7Y9WZcin3a5XX1qYuVUOvxxHgDXYaCVYiuHguViexMxgHgKnP6QW_JYwXD3QfbWBgzqgZLM7w4Ej-F7lQZKEeW2e0sEBtkrzRuVecPJ73_SkQNCG9yTWsFc89f3OpqnFjln8axUoi_0e9_RZgHuaDz2JoKhyERhFv5UqRQwp8x3_LabpCNSA_5D_zVm4cvpg4dI_LjcgpCbPOStZFN8i9i7CqNVacYeAQOoGZEuIrreRSIqBPdAklczmuYfwdQWsZ2Ac1UiumO9r4OunBSudIHdEmkAO9LT_kCIKL0sbYY1dm58JpkvCdZOUaHMFxKjtk00AVkKXCONboGa4d__Fvt5rpXmgs00i10POpBm6Xbp50r2ANZ5G_7KbHI5TaDAu98OvQuqTPlpr3kJUz1IODysK8o9aoLwQroD2lc-YcNaCSyKUi2T4YIYMileWEiXC5fGyiUxqlHgpA=w1188-h789-no
zExrw2LuQoq7rorvHs8D49rCl0ve4TEXZyN_1JZ0kq0aximN5SJUBd_bs5vxD2_GBRsf3VlrQEea4XIFrz_CZnFH_0U_a99u5Owar794r3fXKBMM8VVvs509aAPyvwNP8jLomXiZqXiQ93eFMVDcIMtjk2w0TKsMe1GsQWXhKMw9emvavH38nlj6ZCAMzoFhXbRy-7Opk9HCRprzZM4Qxra1zgvAil10m6XMjKdtB6qdLtSwrppIi5oQISTqP_ppSm4K_VmyxoBvePFiSF5z_UDhmFf4tkcY8NYrf6BSAlJ97gLmWjXFbgFyJT3oiG-bP3yw9DCv9dtkXGGSNujzjd5oSq5v0MJ86i0hCkU_p6AjQ3rEn_vLcqYJBsEMD4o5QutzvGLsJT048Tg2oJAJPwcuSlJCfINj3buxhpQc70529IBMOhLjJ_UqPVCSO-jOOVIXWIfHHCAqFg2XVDDa8OFwCQ0HhTgm88SMmLCvo9XG_rYOC8Dxjj0nXtoOeGZNaNsW9TAX1nr4_lHVHUaYvYxdTJGfWhTTb4JuMIuhoDGF30PzWGvYXP-9wX9rTURcq8U0tm4Z3z-kpTe2uENkvhCW2IB35exaehuqU4shH4M6AZ4_GVbC3UoN83kNalEL9RyJ-GG2rCkFchAMaQhPiT1rQMAAeE94zL95OIgciUye1t6J4R85J0HPF41EyA=w1188-h789-no
I have the bottom felt and the bushing from the battery tray. What I don't have is anything that holds the radiator into the cradle. It appears my side brackets on my radiator are no longer there. Is there any kind of rubber that goes on the bottom of the radiator or is it just those brackets that suspend it into place?
Your radiator should have a full height flange on both sides that align with the side of the radiator support... This suspends the rad so that is does not 'sit' in the support.
