What have you done to your Land Cruiser this week?
Drained the water and the 3:70s from my rear diff, added oil, 4:11s, axle bearings and seals.
Sanded the surface rust off a new-to-me hood then sealed it before a thick coat of primmer.
is this an OEM part ? pic ?
not an oem thing...Purolator brand...replaced with a mr.gasket one of the exact same style and size as this picture:
Replaced the radiator with a radiator barn HD 4 row, had to oval out the mounting bolt holes as it did not clear the bottom of the radiator frame. It hits the frame with the bellied bottom on passenger side where the return to the motor is, think I remember seeing a similar post in the past. Anyway an hour turned into three to get it to sit level and straight, but ready for summer now.:eek:
finished the family cage on my 1980 and installed my JimC rebuilt carb on my 1971.
i finished my cage to frame tie ins, and built a new skid plate to cover the sm420 and also instlled a new champion aluminum radiator. im tired and moody now
:idea: aha
thanks for the info :cheers:
Installed an aluminium fan shroud......
Got it from Speedway Motors. It's one of their universal units. Pretty easy to deal with, just used a jig saw to cut out the fan hole. Then I riveted four of the included brackets to the side, drilled some holes through radiator cradle, and screwed on with some sheet metal screws.
Huge difference in idle temp. I drove it around for about 10 minutes then let it sit idling for about 30 and it never went above 170.
I built a front bumper/air tank to go with the Warn power plant. The compressor provides plenty of air to the 3 gallon pressure vessel. On the drivers side I have a glycerin filled gauge to show working pressure and a + and - source for jump starting jeeps on the trail;). I had it sand blasted and powder coated to match the winch. Tomorrow I will be wiring it all up using #2 ga. fine strand welding lead and running DOT push style fittings for the air connections. Two Q.D. on either side located inside of the frame mounting brackets as well as a drain plug, air servicing (fill) valve. Check out the pictures.
http://imgur.com/IuCA6http://imgur.com/W6EMOhttp://imgur.com/1rbPWhttp://imgur.com/UGCDchttp://imgur.com/zs8NI
Please,
Can you post the pics below each other instead of next to each other?
Thanks,
Rudi
http://imgur.com/IuCA6http://i.imgur.com/IuCA6l.jpghttp://imgur.com/W6EMOhttp://i.imgur.com/W6EMOl.jpghttp://imgur.com/1rbPWhttp://i.imgur.com/1rbPWl.jpghttp://imgur.com/UGCDchttp://i.imgur.com/UGCDcl.jpghttp://imgur.com/zs8NIhttp://i.imgur.com/zs8NIl.jpg
:popcorn:
