I have always wondered that. I work in the boat building industry, sika and plexus basically rips the composite apart. Wonder if anyone has tried?I gotta wonder with the sikaflex if you even need the rivets anymore.
Ohhh Porsche 914s That was what I wanted when I was in HS. I hardly ever see them any more.I finally got around to putting all new windows felts in. I've had the parts for close to a year. It's a fiddly bit of work, but like most things, the first door takes some doing, undoing, re-doing and the second one takes 20% of that time. So satisfying to be able to close the doors and not think you are going to shatter the glass.
If you really want one, the orange one will be for sale at some point. I need to put it back together after getting it paintedOhhh Porsche 914s That was what I wanted when I was in HS. I hardly ever see them any more.![]()
Did you go OEM Toyota on those? I tried aftermarket and they did not seal right. So, now I have OEM ones to try. The toyota part numbers on door parts is nuts. I have so many extra parts that I basically bought trying to figure it out.I finally got around to putting all new windows felts in. I've had the parts for close to a year. It's a fiddly bit of work, but like most things, the first door takes some doing, undoing, re-doing and the second one takes 20% of that time. So satisfying to be able to close the doors and not think you are going to shatter the glass.
The weather strip or scrapers at the bottom of the window opening were Toyota parts. The upper channel run was purchased from City Racer as described below. Lower channel bought from him as well. Those all worked great.Did you go OEM Toyota on those? I tried aftermarket and they did not seal right. So, now I have OEM ones to try. The toyota part numbers on door parts is nuts. I have so many extra parts that I basically bought trying to figure it out.
Is that a turtle box speaker at the top frame of your window? If so .... How do you like it? And is I loud enough as you're cruising at a higher speed?Took my top off and found another sad 1980 girl pulled out of a collapsing building and trees. Tubs toast . Trying to get it for what few parts are left before going to scrap.
Turtlebox is great, one of my best friends from college works there. I’ll let @Buffchief comment to the volume vs road noise but I don’t think you’d be disappointed with it.Is that a turtle box speaker at the top frame of your window? If so .... How do you like it? And is I loud enough as you're cruising at a higher speed?
How much elbow grease did it take to get the canopy that nice looking?broke down and put the wipers on - not exactly a cake walk with the hard top on... lost count of how many times I dropped the nut trying to squeeze my fingers under there
Thanks for your responseTurtlebox is great, one of my best friends from college works there. I’ll let @Buffchief comment to the volume vs road noise but I don’t think you’d be disappointed with it.
