First time swapping timing belt. Also got the water pump, fan bracket, and heater T's. Managed to snap my fan shroud in half putting it back in
Timing belt was still the original. 143k miles, 23 years.
Nice job!!!
The top tank of that radiator appears to be color shifting. Might just be the photo.
If the plastic is gray/ green/ brown… it’s time to replace with new OEM.
When the plastic tanks change color, it is a sign that they are becoming brittle and may fail unexpectedly and quite dramatically.
Also… looks like your brake fluid reservoir may be overfilled. To check, I would use a turkey baster to remove fluid from the reservoir down to the level in between the max line and the minimum line. Then with key off, pump the brake pedal 40 times. For reference, it is written on the top of the brake reservoir cap. You will find that the fluid level in the reservoir will rise by approximately 1”… what you have done at this point is release all of the stored fluid and pressure in the brake accumulator.
After releasing all the pressure, that is when you set the level of brake fluid in your reservoir to the max line. Next, you turn the key on, engine off, and use a stopwatch to time how long the brake booster pump runs until it stops. 40 seconds maximum, with a fully charged battery.
When the brake booster pump stops running, observe the level of brake fluid in your brake reservoir… that is the maximum healthy level for brake fluid. … it should be somewhere between the min line and the max line. Never top off brake fluid without performing these steps… or, during normal operation, the system may discharge brake fluid out the cap, which will run down the brake reservoir and can cause catastrophic damage to some very expensive brake parts… like the booster pump motor, and associated electrical connections.
Here’s a link to more information about 100 series brakes than you’d ever want to know.
First and foremost: Brakes should only be worked by those, with high level of mechanical abilities and experienced with brake systems.
With the age of all 100 series today, in our aging fleet. Any issue, with brake master assembly. IMHO, best and safest course of action. Have the whole brake master assembly, replaced with new. If you have to ask question, on "how to", your not qualified to work on the master.
My hope is below link will give better understanding as to what we can do to reduce brake failure and what to watch for. The info is from my experiences and my thinking, as to what...
