What does the carb diaphragm do? ISSUE SOLVED!!!
I posted the following in the 60 forum, but I figured there are probably several 2f/carb gurus in here that may be able to help me . . .Thanks
As the title states, What does the carb diaphragm do?
Here's the reason I ask. I have been having an afterfire (backfire out the tailpipe) problem on deceleration. After hours of testing, I am 99% certain it is the decel fuel cutoff system. Simple enough, but all the components of that system are working (vacuum switch, solenoid, wiring, computer). I have taken vacuum readings at the switch and it is getting plenty and it varies depending upon RPM. But the fuel cutoff solenoid doesn't seem to kick in properly. I can manually (applying and removing 12v) get it to function and it stops my afterfiring problem.
So my thought is that the vacuum signal going to the vacuum switch is funky. Since it gets the vacuum from the slow circuit in the carb, I am wondering if the problem may lie there. And since the diaphragm seems to be connected to the 2nd (slow) throttle valve, perhaps that is my culprit.
The strange thing is the car car runs fine - other than the afterfiring. Carb gurus, please help
