Hi,
I had to move my charcoal canister (I think that's what it was) to get the A/C lines unhooked at the firewall so I could pull my evaporator. When moving it. I noticed the bottom hose (cut at @ a 45 degree angle, like if you were cutting stems of flowers prior to putting them in water) wasn't attached to anything.
1) This is the charcoal canister, right? It was mounted by two bolts just above the a/c lines on the firewall, and has three rubber hoses, driver side, pass side, and directly underneath.
2) Does the hose underneath attach anywhere, or does it just hang down? If so, where, and where would I find it in the FSM? Again, the bottom hose is cut on a slant, like the stem of a rose.
It doesn't seem to be effecting anything as it is, but I'd like to make sure.
Thanks for helping this idiot out.
