Install new timing belt, water pump and seal kit - All Toyota parts
Install new serpentine belt - Toyota part
Install new radiator hoses - Toyota parts
Install new antifreeze - Toyota red antifreeze
Repack wheel bearings and check CV/boots
If front brake pads are worn more then 50% replace pads
Replace/flush brake fluid
Replace fluid in front and rear differentials - use synthetic fluid.
Replace fluid in transfer case - use synthetic fluid.
Service transmission
Grease driveline and front suspension.
"Not a dealer its being done at a local independant shop".
Figured since the serpentine belt needed to be replaced I might as well have the timing belt done since it's past the 72 months but only has 58K miles.
