Looking for a level lift for a 1997 LX450 and have come up with the setup below. Purpose is mainly street, easy dirty roads and snow. Stock front bumper and no heavy loads anticipated.
2” springs and shocks (from MUD member)
Metaltech front 1.5” coil spacers
Dobinson 15 mm rear spacers
3” MAF drop brackets for caster correction
MAF sway bar brackets, steering damper, bump stop spacer
Questions:
Do you think this will be close to level -a bit higher in rear is fine)
Do you think the .5” difference between the 3.5” of total front lift and 3” MAF drop,brackets will be a problem for caster correction? Should I go with 4” MAF drop brackets?
Am I missing anything?
Thanks!
Questions:
Thanks!
