Put these in
And cut and patched this
I don't know who's shoe that it...
Waiting hoping to pick up tcase and h55 from torfab this week so I can start looking at making a crossmember.
Put these in
Put these in
Sweet ! Could we get more info on light bar and how it got mounted?
Thanks
Light bar is a 50" Curved Cree Bar that a got on a group buy at Tundratalk.net for $130 ish, I plugged the group buy in the 80's tech forum a couple months ago. The bar is divided into two main sections the edges, about 10 inches on each side, are floods while the center is comprised of spots. Each LEDs' output is rated at 300 Lumens. The approximate draw is 30-40 amps when on.
I used the mounting brackets it came with, they were cast aluminum and squared at the bottom. I had to do some grinding and shaping to the foot to make it contour correctly with the roof. Once I had them shaped I marked out the roof drilled through and used carriage bolts with the flat side inside to mount the brackets. Between the roof and the bracket I put in the included rubber isolator pad and I siliconed everything. It is very stout.
looks good, any chance it could be pushed back and mounted to the gutters??
Im sure you could, You would have to make a custom mount though and IMO I don't think it would look anywhere as good pushed further back from where I mounted mine. Even though it seems scary to drill through the roof, as some see any penetration as a leak point, if you silicone your work properly there will never be an issue.
Also the way my bar is mounted it doesn't jiggle around even slightly. If you push those mounts out farther to the rail (which IMO isn't even that strong) then you run the risk of getting more jiggle in the light. Which is not good.
Was tired of the wimping lame misting the windshield washers did. Modded the factory windshield washer by eliminating the rear window switching valve, softening the bends in the lines, and porting out the hood emitters. Now I have 4 solid streams of water hitting the windshield. The guys behind me on the freeway will love it almost as much as me.:hillbilly: A well needed mod for all the mudding I do. :rolleyes:
Drove it to work Friday. Halfway through the morning, one of my coworkers came up and said his cousin got his van stuck on the side of the road. I was too busy to do anything right then, so tossed him the keys and showed him the strap & D-rings. He came back wanting one.:worms:
Only problem was, when he first got there, the cousin started unspooling the winch, and they didn't know how to get it back in. :bang:
I went riding with 4xFletch (he earned his Crazie Eights decal).
Looks like you guys were back to having fun up there! I'm anxious to get back up soon.
Nice. I still think you need to put all your "fixes" in one thread. They are all great.
You stated "porting out the hood emitters", did you just drill them out to become one?
meant to post up last week but have been too busy. drove the cruiser from seattle to atlanta in 4 days, averaging 75-80 mph the whole trip. Was getting around 12 mpg (i have stock size tires, and the tjm 50mm lift)--thank god for the drop in gas prices. first time driving that kind of distance for me, and certainly for the cruiser. great driving experience. the shane's leather, new seat cushion, and heated seats were welcome parts of the trip.
Bought it. Brought it home and started getting to work on mods. Couple small ones to start. Painted door handles and flares.
Before:
After:
flares before:
flares after:
Looks good. Rattle can paint?
I did some miscellaneous wrenching this weekend, and a little bit of dirt road rallying.
Completed:
-Hand throttle install
-CDL switch install
-Replaced rear dome light
-Replaced thermostat
-Replaced heater valve
-Replaced #2 and #3 radiator hoses
Still no heat in the cabin. Rear heater works but I'm starting to fear that my heater core is plugged up for the main cabin heater.
Looks great box rocket! Always liked non-roof racked 80s w/front mud flaps!
MrMoMo nice rack, how much does that way?
Hmm, good question - not sure, but definitely not a lot, I carried all the pieces into the shop under one arm.... I'll weigh it once it's all together...
