What did I miss? Replaced the starter contacts and it's still not working!!!
Kalispell, MT
I spent 4hrs today changing the starter contacts with new Toyota contacts.
It was 25 degrees out and my fingers are still a bit sore from twisting bolts and nuts. I've had too many hours in the office haha.
I pulled off the intake and pulled the starter out without too much trouble. The boards over the engine compartment trick was great advice!
I installed the new contacts with the instructions in the beginning of the FAQ starter contact replacement thread. My old contacts were worn. I placed the new contacts in the starter in the same order and what looked like the same alignment.
Now, I read somewhere about a wood block to use as a jig here? Or others had used a c clamp? I didn't read into why, and now I'm kicking myself.
When I re assembled everything I tried to start it and got a "click" and "hmmm" noise. No start, no turn over, no nothing. I checked all connections again and found one behind the driver side starter bolt that I forgot to plug in! Hallelujah!!!
Nope that wasn't it (F#%€ck!!!) I should have tried the stater when the manifold was off!
Spent the next half hour looking for any missed connection or bolt. Everything is plugged in and bolted up.
I also installed a brand new battery at the time of the repair. The connections are tight and the door ding and lights come on when I turn the key.
Any ideas? Did I miss a step in the contact repair? Could the starter be bad in a way that contacts can't repair?
I usually don't have much frustration with non completed repairs, but with the cold and limited time this one has me wound up.
Update:
I just found a FSM screen shot that specs what the wooden block is for. I will post it up. I under stand now looking at it what some are using a C clamp for.
I also checked the EFI relay under the hood. I tapped and tried to start it. Nothing. I removed it and jumped the connections with jumper wires, then tried to start it. Nothing.
I guess I will pull the intake back off and dig into the starter unless someone has a better idea?
Here are photos of the contacts and the fsm
After reading and re-reading every thread I can find on starters and starter issues, I have ordered a new Napa starter.
Some how I messed up the starter contact replacement procedure. I will know more when I pull it apart tomorrow. If the contacts are not fubar I will be offering them up at a steep discount to who ever wants them.
The Napa starter is all new and comes with a life time warranty. It cost $105. Toyota does not supply a new starter, so I am hoping this will outlast the rebuilt OEM replacement.
Ill update with more photos tomorrow.
I installed a new napa starter yesterday and it works great!
It took me 2 hrs and 40 minutes to remove everything, install the new starter, an reinstall everything. Practice saves a bit of time. I am not completely sure what I did wrong with the contacts, but if I did it again I would just get a new starter.
The best tip I learned from Mud were to place towels and then boards over the engine from fender to fender. I adjusted there position depending on what I was working on.
The Intel about the driver side starter bolt was good as well. I disconnected the driver side wire connector and bent the bracket holding it and another connector up to give me a straight shot to the bolt with a short extension and a 14mm socket.
I'll post some more photos
The boards over the engine compartment. This made the job much easier and my patience much higher
The location of the driver side starter bolt with my short extension and socket on it. You can also see the connector I removed.
Glad you got it figured out! I read your initial troubles but didn't have anything useful to add as when my starter went out I just replaced it with a reman'd Toyota unit.
Hope you have good luck with the Napa unit.
I included a photo of the location of the (2) 12mm bolts that connect the wiring harness to the starter.
One last thing I found was helpful. When removing the intake manifold by my self it is hard to lift it off of the four studs. I lifted the front off the front two studs and placed to scraps of 1x4 wood under it. Then I could lift the entire intake out without it binding on the studs.
I just did mine last week with 168,000 miles on the clock, and I also changed the plunger since was all corroded.Did you change your plunger? Maybe it was corroded as well.
I did change the plunger with a new Toyota unit. I did not do any bench testing before install and I think that is where I failed. I'm not sure if my install of the contacts and plunger were wrong or if the rest of the starter failed.
I am giving away the contacts if anyone wants them? If not I'll not bother to take them out of the core when I return it.
Sorry to hear your troubles but glad you are up and running. Bench testing is something I always do having been through the same problem years ago. The positive is the lesson learn will never be an issue ever again.:D
