What are your hub to fender measurements?
Norcal
I have kings 2.5 shocks installed on mine. Just ordered a TJM T13 bumper and a winch so I'm going to have to adjust the shocks again. The first installation had the fronts at 21.5 which is a bit low for a 2" lift. Would it be crazy to adjust them to 22.25 - 22.5 in the fronts? I don't want to mess up the CV due to extreme angles.
Stock (Not sure how accurate this is)
Front 20.25
Rear 21.25
OME shocks
Front 21.5
Rear ~ 22.75
Kings current measurement without front bumper.
Front 21.5
Rear 24 without rear bumper. I think it sagged an inch after a rear bumper install.
What are your measurements? Any issues? Thanks!
I just installed OME 2702 and rear 2721 +10mm rear trim spacers and am at:
Front right - 22.5
Front left - 22.75
Rear right - 23
Rear left - 23
I am
23.25 Front
22.5 Rear
I need to install the rear spacers. I have them sitting in my garage. I also have the front spacers sitting in the garage too. :hmm:
I just measured mine but I don't think I was using the same points of measurement. How exactly are you supposed to make this measurement? From what point to what point? Will post numbers once I get that figured out for certain.
Very center of hub, vertical to fender lip.
Front right - 22.5
Front left - 22.75
Rear right - 23
Rear left - 23
Are these measurements after the springs have sometime to settle in? When I installed my OMEs, they dropped almost an inch after the springs settled.
when you say OME .. do you mean BP-51's ? I thought the BP-51 would give a 2" lift?
My rear is at 19.75" with rear ARB bumper and storage boxes.
My plans are to install measure and then lift.
I'm waiting on front bumper, and rear aux fuel tank.
Not sure if there is a different fender height between years?
Front 19.5"
Rear 19.75"
Front 19.5"
Rear 19.75"
Not the BP51. Just the regular OME nitrocharger shocks.
On mine ome 2702/2722 with roof rack, and ARB drawers I have 22" in front and 22.5" in rear. Thinking to exchange rear to 2723
