What are you working on? (15 Viewers)
Got out the solder iron so I could put my frame harness back together after the stretch.
Small things matter, at least what I keep telling myself haha. It took a big nut but finally was able to get the plug out.
Started the throttle linkage
For stuff like that a welder is a lifesaver. Make sure you hold your breath when welding galvanized nuts
Not galvanized but the lighting sure made it look that way. But yes, galvanized steel is nasty stuff...
One step closer to my triple locked dreams. Lockers, axles, and wiring ✅
Now I just need time and axle seals etc to rebuild the front and rear when they come apart
The alternator has been making noise since the Potts run last year. Made a bunch more yesterday and stopped charging. Today it was seized up. New one on and ready to go.
Love the belt routing in sharpie. 😁
Who will have their's running again first? tic tok, tic tok
My money is on Mike
But I was able to get my TS installed and my TBi to intake manifold adapter installed along with a couple other gaskets
New rotors and pads. And new ARP axle studs. I'm not sure I like how far they stick out but the old ones were bent.
I also pulled the bearings out for a repack but the grease was still nice and pink so I just added a little more and put them back in.
Tire rotation will also be done.
I did ARP axle studs recently, they didn't stick out that far. Not 100% but I think one side of the stud is longer and the longer side goes in.
you probably already saw it, but it looks like your bump stop bolt has backed out?
