SOLD West Virginia: 2003 LX470, 153K, Former FL Vehicle (Sale Pending....)
Year
2003
  1. LX470
Mileage
153500
Color
black
Price Reduced to $20,000 OBO - My Wife wants her side of the garage back...
As much as I love my '03 LX470, I couldn’t miss the opportunity to own the last year of the 200 series, and pulled the trigger on a '21 Heritage Edition .
Thus it is time to pass this fine vehicle along to someone else.
2003 Lexus LX470, 153,300 miles, Located: Milton, WV. Price $22,000. obo
I am the second owner of this fine vehicle. I purchased it in 2014 with 92,500 miles from the first owner who lived in Florida. He was a nationally renowned physician, and this was his wife’s car. They performed ALL maintenance on the vehicle at the original selling dealer as you can see by the attached Lexus owners report. No expense was spared on the routine servicing. They even had a monthly detailing done on all of their vehicles. Suffice it to say that it never left the pavement, nor did it suffer from poor upkeep.
I do my own service work, with the limited exceptions of recalls and those items that are beyond my abilities. I have tried to carry on the first owner’s tradition of excessive detail to routine maintenance. I will included photos of my “black book” of the items /maintenance I have performed.
The vehicle is bone stock with a couple of small exceptions - I couldn’t see to drive it at night with the stock headlights, so I did change out the projectors to the Mini H1 HID projectors /ballasts/ bulbs from the Retrofit Source and was one of the first customers of @Luke111 for his custom brackets for the projector retrofit. The change in light output was definitely worth it. The only other item is a YodaMD Key housing to replace the OEM one.
I haven’t taken this vehicle off road, unless you count the 2 mile gravel road I take to get to my farm...
Highlights of upgrades / replacements under my ownership:
  • OEM in-bumper receive hitch added (although never used) – Still have the original cover plate if the new owner wished to remove it.
  • Air Conditioning amplifier (electronic brain) went out – Dealer replaced
  • Dealer also did the side impact airbag Recall work a few years back
  • HID Projector upgrade as mentioned above.
  • New Michelin Tires at 147,000 miles
  • New Radiator (OEM Toyota) and toyota red coolant change last year.
  • Heater T’s have been replaced.
  • ATF, Transfer Case, and Diffs all baselined around 110,000 miles
  • AHC fluid changed / Flushed (AHC operates perfectly)
  • Synthetic Oil changes on 5,000 mile schedule - Always Toyota Filters. I’ve been using Royal Purple oil in all my vehicles the past few years.
  • U-joints and Drive Shafts always greased on same schedule as oil changes
  • Serpentine belt and pulleys were replaced last year with OEM
The timing belt was replaced at 75,000 by the dealer for the previous owner. Thus I would recommend the purchaser plan for a timing belt / water pump replacement at 175,000 –200,000 miles.
Since this is a 2003 model, it does have the 5 speed automatic transmission, and it still has a transmission dipstick unlike the 2004 and later. It runs and drives just as it should. All electronics and the AHC operate properly. I re-foamed the OEM speakers and subwoofer a few years back and replaced the speaker cloth.
The paint / body is a 8.5 out of 10. There are the usual rock chips on the hood which have been touched up. There is a small scratch on the grey part of the tailgate. The rear bumper cover has minor parking lot scuffs on both corners. And the drivers door has a small edge chip (touched up) where it was opened into the side of another vehicle. All of the above are shown in the photos. There is one spot on the passenger side carpet, which is entirely hidden under the weathertech floor liners -see pic.
I have included several photos under the vehicle - the typical rust on the gas tank skid plate and exhaust, and some limited rust on the frame. In the northeast, this would be a “rust fee” vehicle.
I just had the vehicle detailed inside and out, and despite my instructions to the contrary, they did gloss up the engine compartment as shown in the photos.
Please let me know if any questions / need additional photos of any areas.
pics
pics
pics
pics
pics - note spot on carpet is completely covered by the weathertech mat
pics
Easier to summarize the service history here than to post another 20 photos of pages of my maintenance history:
MILES ITEM
93,000 Oil Change NOTE - synthetic Oil / toyota filter at ALL oil changes and U-joints/drive shafts greased at ALL oil changes K & N Filter Cleaned at all oil changes
93,500 AHC flush / pressures into spec
95,500 Denso Plugs & Valve Cover gaskets
98,310 Oil change
99,890 Nav Map update
102,975 wheel bearings greased - Brake pads all around
104.XXX Oil Change . Sylvania silverstar Headlights, Fuel Filter
110,XXX Oil Change
112,600 4 Michelin Tires
115,404 cabin air filter
116,000 Oil Change Heater T's
117,008 Right CV Axle (busted Boot - Rebooted OEM axle installed) Front Diff Fluid
118,500 Transmission filter / fluid Toyota IV fluid used
119,950 Transfer Case fluid
119,955 Mini H-1 projectors / Morimoto HID bulbs ./ ballasts, Oil Change
123,740 Serpentine Belt and tensioner / idler pullys
124,374 Rear Diff Fluid
124,890 Oil Change
127,500 Front Sway Bar bushings and end links (originally used MOOG - Almost immediately the bushings failed, so I replaced with Toyota bushings - I have the toyota End links to go with the vehicle, but so far the moog end links are hilding up)
127,500 Upstream and Downstream O2 sensors (Denso)
132,300 Oil Change
137,941 Oil Change
140,XXX H-7 AGM Battery installed
142,243 Radiator and hoses / Toyota Red Fluid / OEM Toyota Radiator / Oil Change
148,974 4 Michelin Tires ./ Alignment / Removed K&N Air Filter - Replaced with Toyota
153,280 Oil Change
I'm in Huntington and would love to buy this, but it's $10k over my budget. Looks like it's worth every penny.
GLWS!
Market is crazy right now but I think you are high... I picked up a southern kept 06 LX470 with 100k miles, good maintenance and not a spot of rust for low $20s (may or may not be a benchmark depending on your perspective). That said it’s worth what someone will pay for it as many on this site will point out...
Lexus service history Attached --
along with additional interior pics someone requested...
He’s a little high on his price, but your truck should not be used as a data point as you got it for way less than market price. If your truck is accident free and turn key then it’s worth an easy $30k. By easy $30k, I mean you could list it on eBay and Autotrader tonight with less then 10 pictures and someone will be willing to wire you the money tomorrow afternoon.
I'm open to reasonable offers.... I'm just hoping to pass this one along to someone in the MUD community before considering the eBay route
Like I said, you may or may not want to consider mine as benchmark. There are plenty of people who have paid similar to what I did and then there are those that paid less and got a great deal and there are also those who paid more which I believe to be a convenience factor for not having to look for 6+ months....Check Cars and Bids and BaT for the pricing as well as monitoring what people say here...
another unscientific method, if you have had people call or message you non-stop from all over the place you either priced low or just right... if your proverbial phone isn’t ringing off the hook with people interested right now, in this market, then you are probably high...
Very nice truck btw... GLWS
My Wife wants her side of the garage back - said to get it sold - reduced to $22,000 OBO
Reduced to 20K
PM sent
sale pending...
