Nice Job so far mate.
What rear diff are you using? 60 series? (apologies if you've mentioned it already, I only skimmed through the thread)
I'm interested in getting discs on the rear of mine too, can you organise another set of brackets?
I'm from Perth too. Good to see another West Aussie getting stuck into a 40!
Cheers
Cheers
It was eating me up, I had to do a rear disc brake conversion. It took two attempts to get the mounting bracket correct (CNC Lazer cut) and three attempts to get the hubs correct in terms of getting the rotors to sit flush on the hubs. The rotors are 60 series fronts and the calipers are front commodores. I had to get the studs machined down to suit the rear hubs which are normally used for drum brake configurations. So yes this did take several weekends, probably 4-6 weeks. SHould be worth it in the end. I forgot, I did FEA on the bracket to ensure its suitable for the duty, see the pic below.
