Shahram
I ain't got herpes no more.
Took the Cruiser out to the El Paso Mountains in the Mojave Desert yesterday. 111º-116ºF, dry as an oven, and some weird stuff started happening. A/C was cranked on the 2 hour drive from L.A. to the trail, no problems. Got to the trail, A/C started blowing warm and swampy air every time we stopped or drove slowly. Trail is a moderate windy dirt road with ruts and some small obstacles. Kept it in high range, figured I didn't need low range at the time. Engine temp gauge started rising. Uh-oh. Never seen it go above half way, at least not in the 4 months I've owned it. Put it into low range, turned off A/C, turned on heater, opened windows. Temp came down pretty quick.
We got to the camp site, had lunch, shot some cans, and after a few hours, we were back on the trail. No problems, but I kept the A/C off.
But, then I noticed that the Center Diff Lock light wasn't on, nor was my ABS disengage light on. I was getting a little worried. Tried locking up the brakes, could feel the ABS working. Kept driving to keep up with buddies, radioed that I might need to stop and think this through. Got to a nice lookout point, turned off engine, discussed problem. Everyone shrugged their shoulders. Turned engine back on. Nothing. Turned it off again. Turned it on, again nothing. Turned it off again. Hung out at lookout for a few more minutes, then decided to head home. On the way back down the trail, after about a minute and a half, Center Diff light and ABS light go on magically at the same time, then off, then on, then fade in, fade out, then gone. Two seconds later, back on again, this time strong. Locked up brakes, no problem. Went back down trail, turned A/C back on because the temp had dropped a little and we were going completely downhill. A/C worked fine, unless I stopped. When I stopped, it blew warm and swampy air again. We got to the road, switched out of Low and back to L.A. with no further issues.
Got back to Santa Monica where it was in the low 70ºs and humid. I've been having a "knock" sound (like a low-grade fuel ping) when I first throttle, which goes away at higher RPMs. Now, accompanying that is a low grumble in first gear. When I pull away from a stop, it sounds like a hibernating bear is stuck in the tranny. A/C is also noisy as hell now. I'm a little worried, but I have faith in the Cruiser and know that these problems, once addressed, will be easily remedied. But I'd like to have an idea what's up before I start trying to fix things.
I didn't wheel the Cruiser hard yesterday at all. Just some moderate dirt roads with some ruts and hill climbs. Any suggestions on what these problems are, and if they may be related? Having 'wheeled Nissans for a few years, I learned little nuances and signs that lead one to the source of potential electrical and engine problems (some of which are so far-fetched as to boggle the mind), but the Cruiser is new to me, so I'm trying to figure out which electrical and other components are related, or located near each other. I'm starting over from scratch, basically.
Sorry for the long-winded post, and thanks in advance for any and all help and info you may give. You guys are really helpful and your knowledge and generosity are not lost on me.
