Weird sparky plug (1 Viewer)
Status
Not open for further replies.
FJ40Jim
The Cruiser Whisperer
Lancaster, Ohio, USA
Website
www.tlcperformance.com
Pulled this plug out of a 2000 Golf, 2.0L.
Customer complaint: no power, runs rough.
Scan says lots of misfire codes, especially on this cylinder.
Picture no worky?:confused:
We'll try a shorter linky:
TinyURL.com - shorten that long URL into a Tiny URL
EDIT: fixed the pic. Thanks Mark!
Anyway, never seen a plug look like this after 2000 miles. Ideas?
No, I' haven't checked compression or injector balance or timing or... yet. Just thought i'd toss this out there for your entertainment.
:cheers:
my god...
Wonder if the gap was fused and it basically welded itself to death???
:eek: Wonder what the injector, piston, and cylinder walls look like?
I don't know if it plasma welded itself to death or if it is FOD.
We'll get a compression test and have a better idea of how bad things are.
Suspect head is gonna be coming off....:hhmm:
I am amazed that you got the plug out without destroying the threads in the head itself...
Or did ya?
Thanks for posting that Mark.
Turns out the plug fell out? while on a trip. Owner had podunk garage drill & helicoil boogered thread. They drilled the helicoil off at an angle (easy to do in the soft aluminum head). This put the plug into the combustion chamber at an angle, exposing too much plug, allowing the meltdown to start.
New complete head assembly, plugs, wires... fixes the problem.
Status
