Weird Electrical/Software Glitches....
BIC JET
GOLD Star
Dallas
Hey guys, for about two months every time I get in my truck and crank it up the HVAC is not where I left it. In fact, it is typically in the off position. So the new normal is I get in, wait for all the software to boot up, then I press the auto button (it is always on 75 when I turn it on), then I hit the rear AC button, then the climate button, where I have to go to disengage the 4 zone. The 4 zone is the bane of my existence.
If any one has a fix to get this back so that it just remembers how it was last time I got out and turned off the motor, please let me know. Only change of any merit is I swapped the battery to a grp 31 AGM.
Thanks
Double check your battery posts are tight. Pull up on the cable, if the connection comes off you found the culprit.
I will check it, but I used the Slee terminal connector.
Thanks,
There are other threads on this issue. Apparently in both the LX and LC battery connection problems or an improperly installed cabin filter can be a culprit.
