4Ruster
2LT Sufferer
Hey I have a 2L with what I think is a faulty starter. I can hold the glow plugs cold for 6-8 seconds and it'll fire up immediatly. However when warm, I still need a few seconds of glow or it won't fire, it'll crank and almost go then not go, I give it some glow and it fires right up. I personally think the starter cranks too slowly to generate enough heat.
I draw tested the starter and it pulled 550 Amps when cranking, seems waaaaay too high for a 2.4L engine. I've also noticed (when bleeding the system when I'm in there) that after about 7 seconds of cranking, the starter all of a sudden goes faster and stronger.
Here's a few videos, how does my starter sound? I'm running dual 650CCA batteries that tested great in april.
fires right up but the starter does sound laboured
Here's a better video, ignore the racket the engine makes, this was before I got the injection pump timed and adjusted properly.
