WaterPORT- On board pressurized shower/rinse system
How does it pressurize of a garden hose
  • Our system mimics a bladder with slight expansion, capturing your homes pressure inside the tank.
    Votes: 1 50.0%
  • You can add pressure by using a pump or compressor
    Votes: 1 50.0%
  • Total voters
    2
Encinitas, CA
Use code "mud20" for 20% off @ www.thewaterport.com
The WaterPORT provides easy access to pressurized water for use at play, work or in emergencies. Simply fill the tank with water using a garden hose and go. Our systems also allow the user to manually fill through the top cap and pressurize with a pump or compressor. Then, anywhere and anytime, release a pressurized stream of fresh running water through the hose nozzle. Our tank heat up in the sun and are made here in the USA.
If you have any questions please email africk@thewaterport.com
that's a nice setup, well thought out. What's the capacity of water, anyone know?
