Water pump?
New Jersey
I’m no mechanic but would like to learn, coolant leak in small intervals, all hoses and radiator we’re ok and then the waterfalls turned on. See attached video, I assume cracked pump or gasket? If so, I’d like to try and tackle this on my own, take off the front shroud, drain any remaining fluid and continue to remove items until I reach the pump? Thanks in advance for everyone’s patience and assistance!
Does shaking a fan blade cause the shaft to wiggle? Typically, a worn out water pump bearing leads to seal failure, but not a flood like your video shows. Is your antifreeze up to par? It's been pretty cold lately in PA, I think.
I agree with @brian , you need a picture from above the harmonic balancer.
nope not even, havent had a hard frost yet. today it was upper 70*Fs
