- Location
- United States
Truck runs and drives, has been my construction debris hauler for the past year or so. I purchased it from the original owner and have maintenance records back to ODO reading of 5.
1-4-86 vehicle purchased 5 mi
1-21-86 ziebart applied, chipstop applied 486
3-14-86 cruise control installed 1,741
3-16-86 overdrive installed 1,767
7-15-95 rebuilt overdrive, new shift fork, shaft bearings, stop screw, output shaft roller bearings, o-rings and seals 147,200
Lots more. You get the idea.
ODO now reads 255k.
The truck has extensive frame rot and had quite a bit of body cancer as well. I cut the body off and patched it. Not perfect by any means, but serviceable as a junk hauler.
I have replaced the rear shocks (OME) and performed an oil change, but that's about it. The rear seats are gone. Interior front is in okay shape.
The engine compartment is spotless and this thing is mechanically in great shape for it's age. It does leak some oil.
My plan was to run it until the frame cracked and then pull the engine and OD, but life forces a change in plans. $2000, OBO located in Seattle. I've driven this rig on the highway and it cruises just fine, but I'd trailer it if you are going more than 100 miles or so.
ODO now reads 255k.
