Hi,
My 1994 VW Jetta Diesel is acting crappy lately. It is very hard starting and occasionally stalls immediately after start up. I generally runs good once you do get it going but has the occasional burp as well. Also the idle is varying a little bit. The glow pulugs are new. The engine to my knowledge is in very good condition. Doesn't burn oil and head gasket etc is good with no leaks. It has good power, so I think the compression is good. Therefore I figure it must be fuel problem. I don't believe it has a water separator so is it possible the fuel filter is plugged and/or iced up? It has been -10-20C for the last month. Although the it still is hard starting on warmer days.
Nothing has been played with and no work has been done recently. For comparison the same car last winter started every time with no problems....
Does anybody have any ideas? I think I will start with the fuel filter as it is cheap....
I am not a diesel mechanic, but mechanically inclined. I am learning between this and my BJ60's.....
Thanks
Thanks
