I recently replaced my steering rack bushings with Whiteline poly. I drove it briefly after that then had it re-aligned. Everything seemed ok. However two days after the alignment I went for a longer drive on some winding roads. Three times within a few miles the VSC activated, causing the beeping, flashing lights and brake activation. It always happened on right hand curves only, and I imagine I was going maybe 35-50 mph.
Before this, the VSC only activated once a couple years ago and that was probably a legitimate situation (freeway transition ramp probably going too fast, again turning right).
I did read through several threads on the subject, and am going to connect techstream to see if anything is unusual and also look into calibrating the yaw sensors (if possible). I did see a few mentions of the clock spring but I did not have the steering wheel off so I doubt that's it.
Any other ideas? I have to believe this is related to the work on the steering rack or alignment.
