Vintage Car Collector--Glendale, CA.
Wenatchee, WA 98801
Beware of these guys. Here's the description with (Notations):
• CLEAN TITLE
• THIS TOYOTA LAND CRUISER HAS 52,718 MILES
• THIS IS A GREAT LOOKING CLASSIC THAT'S UNCUT AND SOLID
• STRONG RUNNING 350 SMALL BLOCK CHEVROLET V8 ENGINE (Radiator leak)
• ORIGINAL 3-SPD MANUAL TRANSMISSION WITH FACTORY PTO FEATURE, 2H 4H 4L TRANSFER CASE (PTO leaking fluid)
• NEW BRAKES AND CLUTCH, NEW MASTER CYLINDER; NEWER WIRING, UPGRADED GAUGES; FACTORY 4X4 IS IN PROPER WORKING ORDER, INCLUDING LOCKING FRONT HUBS (One hub will not turn; master cylinder and clutch cylinder both leaking, back-up light disconnected; brake light not working)
• SOLID FRAME, UNMODIFIED SUSPENSION (Painted over rust)
• DRUMS ALL AROUND, BUT ABOUT AS GOOD AS DRUM BRAKES EVER GOT FOR A 4X4 (Emergency brake doesn't work!)
• RUSTIC GREEN PAINT JOB (Bad overspray), NEW WHITE RAPTOR TOP COATING
• NEW DASH PAD, NEW MATCHED HIGH-BACK BUCKET SEATS IN BLACK AND WHITE HOUNDSTOOTH (Loosely attached with no adjustment), CUSTOM GAUGE CLUSTER WITH HIGH-END VDO GAUGES Many holes in dash) MATCHING ASH TRAY AND GLOVE BOX DOOR (Stick-on vinyl)
• MATCHED SET OF BFG RADIAL ALL TERRAIN TIRES ON PAINTED STEEL RIMS (Two tires are trash=flat and won't hold air)
• ADDED PERIOD ROLL BAR (Blocks access to the ignition)
• WELL MAINTAINED, GARAGE KEPT (RUST)
• RUNS AND DRIVES
I bought this based on a 100% Five Star rating on E-bay. I was going to inspect it but developed heart problems (See my early posts on the trip) and ended up in the ER at Redmond, OR. I posted a negative feedback on EBay and it "magically disappeared". Wonder how many more negatives have "disappeared"?
Link?
FYI: GOOGLE is your friend! :doh:
BTW: While looking up the link, the BBB came up. Six complaints/issues and numerous ratings.
:rofl:
