Well Mark,
Not to argue with you, but my experience with my OME suspension lift and drivelines was just that: severe vibration after lift, new output bearing on the t-case, new companion flange, with the problem solved by straightening and balancing both driveshafts but only AFTER I replaced the u-joints. Replacing the u-joints was the last thing I did after all of the above failed to rectify the problem. Like Yellowdog, the vibration did not exist prior to the lift. New u-joints, in my case, was the right solution and ultimately eliminated the vibration.
Again, every setup has its quirks, but having installed castor correction shims with my OME suspension, the truck handled very poorly and after several conversations with 3 different ARB tech reps, I removed them and handling performance was restored. ARB's official stance on this issue is that castor correction is built into the spring system and no additional correction devices are required. This was certainly true with my setup, but each situation requires its own solutions.
I write from my own direct experience, as do you, both of us with the intent to help.
No disrespect intended,
-dogboy- '87 FJ60
