VEVOR Transmission Jack Modifications (1 Viewer)
PAToyota
Keystone Cruisers
South Central Pennsylvania
So I picked up this VEVOR transmission jack a few weeks back when Home Depot had them on sale for $132. As luck would have it, the local grocery store had a deal on Home Depot gift cards that week too - 10x fuel reward points. So I got a $135 gift card and got $34 off my next fillup - bringing the price down to about $100 plus tax.
Overall, for the money there wasn't too much to complain about. Yes, there are better options out there. They also start at $600 and go up from there.
The three things that I noticed in assembling it are the cradle, that the release lever is awkward - particularly if you're trying to keep a hand on balancing or maneuvering a transmission as you lower it, and the bolt holes through the legs aren't sleeved so the tubes flexed a bit and I was a bit worried about stability over time.
I decided to address the legs, because that was the easiest to start with. So I tore it apart, drilled out the holes, and sleeved them.
Then, because I can't leave well enough alone, I stripped the legs down and sandblasted them.
And then powder coated them before reassembling everything.
It feels a lot more secure now. I'm likely going to work on the cradle next to improve it. I'm not sure if I can do anything about the release valve to turn it into a foot pedal.
Oh, and while the powder coat oven was warmed up, I coated a couple cutouts I did on the plasma able while I was at it.
Those jacks are handy. I’ve had one for a few years and have made bolt on jigs for removing T-cases, transmissions and front axels when working alone. A must tool to compliment a two post lift.
nicely done!
that thing does look rather spindly when fully extended, though. Does it seem sturdy enough?
I haven't put anything on it yet, but extending it fully and shaking it around a bit I don't think there will be any issues. As I say, I'm likely going to make some modifications to the cradle to make it more useful.
One of the mods I did on the cradle (aside from custom jigs) was to tack weld the nuts to eliminate the need for two wrenches. It will be obvious which ones to tack.
I will also add these jacks are pretty stable when extended into the second stage.
Totally agree. Why don't people seem to understand captured (or welded) nuts any more?
Because it costs more to manufacture.
Greed
I suppose that over 1000's of units the pennies add up...
I'm finally getting my 2-post lift installed next week and am thinking about other things I'll want now that I have the lift. One of the items is a transmission jack and I've been looking at similar cheap ones like the Vevor. I'm probably not dropping too many transmissions. my use case is more helping with skid plate removal/reinstallation and tire install/removal.
Wondering what others have done adapting transmission jacks to other uses like above. For help with skid plates, I was just going to make some kind of flat plate/table with a rubber non-slip surface and attach it to the jack. I want to be able to remove/install by Bub Built steel skids by myself with no help.
For tire removal, I want to do something like this: TRAC Tire Rotation Assistance Cart | Order Now - https://www.liftwithtrac.com/products/lift-with-trac. You can buy the cradle part by itself (though its $400) and then attach it to a floor jack or something else (like a tranny jack). Has anyone made some like this. Removing a 100 lb tire while standing straight up and not having to wrestle it would be awesome.
